I just finished reading Vance Dickason's "Loudspeaker Design Cookbook" (6th edition) for the third or so time, this time with pretty detailed notes and lots of questions! I was wondering if people wouldn't mind taking a stab at them
I'll post one chapter per reply and perhaps spread them out so people don't get too bored!
I really enjoyed the first chapter. Some of the things that the author compares and contrasts that I'm interested in are:
Problem is I have already decided on the woofer and midrange for my new 3-way project. So, I was wondering if anyone might know what features these drivers have in the areas outlined above, so I can reread this chapter in light of what features these drivers have? The woofer is a Scan Speak 25W/8565-01 and the mid range is a Audiotechnology C-Quenze 15H 52 06 13 SDK.
What I've managed to find so far is:
Features of Scan-Speak 25W/8565-01:
Features of the Audiotechnology 15H
So, I'm just curious if people know a bit more about these two drivers than the published information in terms of the first list of items?! I'm guessing that some of the things might be lumped under the SD or SD-1 designations? In some cases, I'm curious how these two drivers address the problems in the list (i.e. cone flexing or cone resonance modes)
Okay, now a few more general questions:
[Q] The LDC doesn't really go much into cone composition comparisons (i.e. the paper-pulp cone of the 25W/8565-01 and whatever the 15H uses ... but they do talk about dust cap materials at length), can anyone outline the differences in cone material has on the driver performance and ultimately the sound (or point me to a good reference on the subject)?
[Q] I noticed in the Madisound catalog that Dupont is no longer selling Kapton to the loudspeaker industry. Anyone know why this is? It seems that Scan-Speak is using fiberglass instead. How does this compare to Kapton? What about the more exotic materials such as glass and titanium?
[Q] The author discusses inverted hard plastic dust caps. Do just plain inverted dust caps have the same advantages and disadvantages? (Also, in the case of inverted, this means inverted with respect to the direction of the code, so "sticking out"?)
[Q] The author discusses "progressive suspension systems" as something found in pro applications, but not (yet) in the DIY / audiophile market. Has this changed and if so, is there a good example of a driver that uses this?
Thanks in advance! Stay-tuned for more questions :T
- pole geometries (straight, undercut, angled)
- voice coil (underhung or overhung)
- back EMF mitigation (high permeability metal in iron next to voice coil, shorted turn / Faraday loop, conductive coating over pole tips (or other similarities such as copper cap, copper cylinder, or shorting ring for flux stabilization)
- former composition
- two-layer versus four-layer voice coils (very interesting actually)
- cone flexing and cone resonance modes
- dust cap (solid versus porous and other related decision such as vented pole piece or vent holes in voice-coil former)
- low loss rubber surround
- SD-1 motor
- under hung voice-coil
- hard paper cone
- Kapton former
- SD system
- EMF mitigation - copper capsule wrapped around the centre pole piece
- high ventilation factor through the centre pole piece, perforation to the voice coil
- under hung motor structure
- solid die cast basket
- Polypropylene cone
