Hi all,
Figured I'd make a thread to document the progress of my up-coming sub build![smile](https://www.htguide.com/forum/core/images/smilies/smile.png)
This will be my first speaker build, so it's going to be a bit of a learning curve, and I still have a couple of questions I was hoping I could have answered![smile](https://www.htguide.com/forum/core/images/smilies/smile.png)
The drivers I've picked are the Peerless XLS10, with the matching XLS10P passive radiator. I was going to go with a Dayton RSS265HO in a ported enclosure, but one day I looked and it had got 25% more expensive - so it was out of the question. Managed to find the Peerless drivers for the same price, and hopefully they should be as good, if not better.
Looking at other peoples designs and the application notes, it seems a volume of ~30L is optimum. I'm going to build a cube shaped enclosure, with the active driver on the front, and the passive on the underneath.
Power will be supplied by a used Paradigm PW2200 amp I found on a forum, which is apparently 371mm tall. I'm expecting this to arrive over the next couple of days, but this will set the side length of the enclosure.
The enclosure is going to be built from 18mm MDF (is this thick enough?), with a hefty brace down the middle. With an external side length of 371mm, this would put the volume at 37.6L, so with the brace, amp and drivers in there, I think it should be about right.
The passive radiator weighs 400g, so I've done some modeling in BB6. As far as I can tell, the system looks like it will perform well, in particular in the area of group delay - a property that was much higher with the Dayton drivers when I modeled them. This is important to me as the sub will mainly be used for music duties.
So far, I've got:
- A router
- Clamps
- Workbench
- Drivers
- Amp (on the way)
- Wood
- Roundover and a bigger cutter bit to recess drivers
I still need to get:
- Hardware for fixing drivers
- Glue
- More clamps
- Veneer
- Spikes?
Pretty much all I can think of so far. I've had a good look at several sites about enclosure construction etc - should be alright with that I hope. Measure twice and cut once and all that...
Gratuitous driver shot for good measure:
Some simulations:
Images not available
Will be crossed at between 80 and 100hz with my main speakers. I imagine the room will help the sub out at very low frequencies to level the response out a bit more?
A few people who've built similar designs mention adding mass to the PR, to bring it up to about 600g - something I think I'll experiment with.
Is it worth ordering up a set of spikes for it?
I'll update this as/when anything else starts happening...
- Tom
Edit: Changed list of stuff.
So far, I've got:
- A router
- Clamps
- Workbench
- Drivers
- Amp (on the way)
- Wood
- Glue
- More clamps
- Veneer
- Spikes?
Some simulations:
- Tom
