Need a replacement Neo 8
  • PHP143
    • Dec 2009
    • 25
    One of my Neo 8s died and I need a replacement. They are backordered to at least late December. Anybody have a spare to sell?
    Bob
    • 10940
    We are doing some work on our site. Please come back later. We'll be up and running in no time.
    • Ray Tremblay
      • Jun 2008
      • 49
      Where do you have the Neo8's crossed at? Which amp/reciever do you have powering them?
      Being defeated is often a temporary condition. Giving up is what makes it permanent.
      The Merlots
      Scanspeak R2904/7000's, Scanspeak 15M4531K00's, Dayton RSS265HF-4's, MiniDSP 2x8, Class D amplification
      • PHP143
        • Dec 2009
        • 25
        Thank for the advice on where to get a replacement.
        I cross them over as seen here
        bob
        • Ray Tremblay
          • Jun 2008
          • 49
          Are you using the PDR or non PDR model? Is the Neo8 the tweeter in your setup or the mid?
          The Merlots
            That seems low from what I've read, that explains why you blew one.
            • PHP143
              • Dec 2009
              • 25
              Hi Ray, the Neo 8s are the high freq -black trace. Acoustat 6 are the mids -blue trace and the subs are the green trace while the full range measurement is red.
              The Neo8s are non PDR.
              I use twenty Neo 8s, only one died so it had nothing to do with crossing over at 1,700 hz. So I dont think that it explains anything.
              They are back in stock at Parts express.
              Bob
              PHP143
              If the first one hundred db suck, why continue?
