In the plans on Curts site there are 3 sizes listed for the sealed. A 7 liter, 10 liter and 15 liter. What is the benefit sound wise by increasing the volume of the cab?
Tritrix question
Originally posted by justphilIn the plans on Curts site there are 3 sizes listed for the sealed. A 7 liter, 10 liter and 15 liter. What is the benefit sound wise by increasing the volume of the cab?
But if you're really looking for bass you should consider the TL box version of the Tritrix.
Parts Express TriTrix MTM TL Knock-Down CNC Speaker Cabinet PairThe 3/4" MDF construction utilized by the TriTrix knock-down cabinets ensures maximally damped enclosures to prevent annoying resonances that color the sound. The speaker cabinets ship unassembled, but are simple, quick, and easy to construct by simply following the instructions in the video above. Wood screws included. Sold in pairs.Note: Wood glue recommended (not included). Use of wood clamps is also recommended.
Here's a build and review thread on them: https://www.htguide.com/forum/showthread.php?t=37387
Enjoy! :TLast edited by theSven; 17 August 2023, 19:48 Thursday. Reason: Update image location and update htguide url- Bottom
Originally posted by justphilWell I have a Table Tuba sub for my low end so extension isnt critical. I think I will build the 10 liter box then. I have a Denon AVR1610 which is 75watts per channel. Will this drive the Tritrixes sufficiently?-Ryan- Bottom
