Dayton RS drivers. Screws or bolts?
  • FlashJim
    • 145
    I have just a couple of small things to get before I start my build.What size are generally used for the Dayton RS28A, RS150 and RS225?
    Just looking at them I would think:
    RS28A - #8 Panhead screw
    RS150 - #8 Panhead screw
    RS225 - #10 bolt/t-nut
    What have you used in the past? Where have you bought nice looking black hardware?
    Thanks!
  • fbov
    • Jun 2008
    • 479
    I use black anodized panhead screws in those sizes, but I also am not taking the drivers out much once installed. Machine screws have great advantages, but watch out for t-nuts coming loose; then you can't get the driver out without damaging the box. I'd much prefer to fill a worn screw hole...
    Have fun,
    Frank
      • 15335
      Drywall screws work well for driver mounting, especially the smaller ones.
      • FlashJim
        • 145
        I've never considered drywall screws. I'll have to take a look! Thanks Jon.
        Frank, I know what you mean about a loose t-nut. I had one spin on me with my subwoofer.
        • Ray_D
          • 164
          Check out this old thread
          Post #5
          Ray
          • FlashJim
            • 145
            Thanks Ray! That's exactly what I was looking for.
            My search skills suck. I spent quite a while this morning looking for something like that and came up with nothing.
              • 1671
              I use these type of things,
              and love them. With the allen head there's also no chance of a screw driver slipping out of the screw head and smashing into the drivers cone!
              • Dr.EM
                • Mar 2010
                • 18
                Yes, I used those screws above, they are solid, and when driven in to LBL they are incredibly secure!
                • joeybutts
                  • 476
                  Man! That is exactly what I was looking for! Closest thing I could find was these!
                  Whether you're a seasoned artisan or a novice enthusiast, shop Woodcraft for expert advice, unbeatable prices, superior brands, and a woodworking experience like no other. Explore our vast selection of premium wood, tools, and accessories, meticulously curated to fuel your passion for creating timeless pieces.
                  Now I need to decide which one's I want to use! :
                  More exclamation points!!!!!!! :roll:
                    • 1671
                    I'm not 100% sure where you're at, but madisound sell a good range of hex head screws
