Cheap Cabinet Resonance Tester
  • oneoldude
    • 203
    Serious DIY speaker builders work very hard at reducing cabinet vibrations. And they do it with good reason. Cabinet resonances can blur and swamp the signal being reproduced by drivers. This often causes that "boxy" sound no one wants. In fact, it has been reported that in some instances cabinet resonances are produced at higher SPL's than the signal the drivers are producing! This is not good.
    There are lots of theories on methods of reducing cabinet resonances. They include cabinets that are: high mass, low mass, stiff, floppy, lossy, etc., etc. I will leave the theory to others. What this post is about is an inexpensive method of testing the success of your cabinet vibration reduction techniques.
    The method I suggest is to use an accelerometer. You stick it on a cabinet and play pink noise through the speakers then take the output of the acclelerometer and feed it to your acoustic measurement system. You can then look at a FR plot of the cabinet's "response". While the pink noise is hissing away you can move the accelerometer to different points on the cabinet and try to determine what is what. You will be surprised at what you will discover. In effect, you are using an electronic stethescope that allows you to see what the cabinet is doing in different places on its surface.
    The problem with this method is that sensitive commercial accelerometers are quite expensive. I will show you a very sensitive tool that you can make for virtually nothing out of what you probably have in your shop. Even if you have to buy the parts it will only cost a few bucks. The idea came from an Audio Amateur magazene article years ago. And it works like a dream.
    The heart of the tool is a piezio element from one of those cheap piezio tweeters (just take apart the T and extract the element). The piezio element has special properties. If voltage is placed across the element it will flex. Indeed, that is the way it produces sound. But the converse is also true. That is, if you flex the element it will produce voltage. So in a sense it can be made to act like a microphone for cabinet vibrations.
    What must be done is to provide a method of attaching the elemet to the cabinet in such a way as to allow the cabinet vibrations to flex the element. This can be done by supporting the element in the middle with a rod that can be attached to the cabinet. As the cabinet vibrates the vibrations are passed to the center of the element and its outer edges are then free to flex.
    The picture below shows my version. The green thing is a smallish wire nut like those used in construction. I filled the base with epoxy to give a flat spot to stick to a cabinet. I epoxied the element to the top and bound the thin RS coax to keep from stressing the lead out wires.
    To use it, simply put a tiny bit of Blue Tac, clay or plumber's putty on the flat bottom of the wire nut and stick it to the speaker (press hard). Run pink noise through the speaker, feed the signal to your measurement system (I have the IMP) and see your cabinet's resonances as a FR curve.
    Some comments are in order:
    This unit is not calibrated so you cannot come up with absolute SPL levels but it will show relative db's on the FR curve.
    I have not used it with measurement systems other than the IMP. But it should do just fine. Some measurement systems might need a pre-amp to raise the signal level, but maybe not. Try it and tell us.
    Surprisingly, even though a tweeter element is used, it is quite a wide band tool and does a marvelous job.
    No, I do not have any graphs to show. I threw out the old ones years ago. But I am building some speakers now and should have some plots to show in the near future. If you beat me to it, post some plots.
    The best way to develop a cabinet is to build a prototype, measure it, then start adding/changing braces, dampening, etc. until you get what you want. You may find that what you are accomplishing is only raising or lowering the frequency of resonances or going from high Q to low Q, etc. Then you must choose what you want. Engineering is all about compromises.
    Hope you find this useful.
    Enjoy!
    Last edited by theSven; 21 August 2023, 10:07 Monday. Reason: Update image location
    oneoldude :later:
    "The race is not always to the swift, nor the battle to the strong, but that's the way to bet" - Damon Runyon
    "De Gustibus Non Disputandum Est" (There is no disputing taste) - Ancient Roman Saying
  • Davey
    • Jan 2003
    • 355
    I bought a cheap Measurement Specialties accelerometer from DigiKey many years ago. ACH-01-04
    1614.pdf
    It seems to work fine although I don't use it much anymore. However, I do like your wire-nut version.
    Davey.
    • oneoldude
      • 203
      My oh my, there are some cheap units there.
      Can it be used without a pre-amp?
      What measurement system did you use?
      How did you affix it to the cabinet?
      oneoldude :later:
        It needs a preamp, just use the same one you use for your measurement mic.
        • thylantyr
          • 127
          I use what Wilson Audio uses.................. a hammer + ears.
          /seriously
          /lol
          :twisted: :rofl:
          • Davey
            • Jan 2003
            • 355
            A hammer....that's high tech. Actually, the way to do that correctly would be to attach two accelerometers.....one to the panel and one to the hammer and then look at a differential measurement between the two when you strike the panel. I'm sure that's the way Wilson does it.
            I built a dedicated preamp for the unit I have, but a standard microphone preamp with 5 volt excitation will work fine.
            Cheers,
            Davey.
            • TacoD
              • 1080
              Wow interesting stuff! My expierence with accelerometers is that the accuracy is strongly effected the way you mount them. For low frequencies it is less problematic.
              • oneoldude
                • 203
                I guess I am fortunate. My mic (Panasonic capsule calibrated by KimG) works just fine with no pre-amp. It does need to be energized but my IMP and my soundcard (M Audio Transit) supply the necessary power and all necessary amplification.
                The accelerometer I show above does not need a pre-amp or power. It works great with my IMP and it cost me about $30 less than the $30 one from Digi Key.
                I am not sure what accuracy means in terms of this aplication. My home brew unit is not calibrated for SPL. However, it is absolutely accurate as to the frequencies being shown. Of course it must be pressed on firmly so that it does not rattle or move independently from the point being measured. My experience has been that it provides replicable results when measuring the frequency and relative amplitued of a given point on a cabinet.
                oneoldude :later:
                • andy2
                  Fighting cabinet resonace
                  by andy2
                  I've just finished building a pair of semi-dipole speaker. There seems to be resonance that materialize itself as a midbass hum that makes male or female voice sound a little heavy or nasal though just a little.
                  The dimension of the internal size is 360 x 540 x 254 mm. The cabinet...
                  29 July 2005, 01:07 Friday
                • lordpnats
                  cost effective speakers for a digital piano cabinet
                  by lordpnats
                  I am planning on building a fake piano in which to put my Yamaha p-90 digital piano. The design will be based on the Yamaha U3 upright which should give me a box somewhere around 52" tall, 12" deep, and 60" wide. I'd like to build speakers into the cabinet and run the piano through...
                  07 January 2014, 10:07 Tuesday
                • joecarrow
                  Ceramic tile stiffening cabinet walls
                  by joecarrow
                  Hi Guys,
                  I've been reading about different cabinet construction techniques, and I came up with something that might be of interest around here. I'm not the first person to come up with this, but I would like to bring up the idea of ceramic floor tile as a stiffening liner in cabinets....
                  11 April 2006, 01:01 Tuesday
                  Measurement Mic on a Budget
                  We have a number of inquires from time to time about what to use for measurement on a budget- most folks aren't in the market for an HP preamp and a Bruel & Kjar mic! And I wanted to have something inexpensive to carry around with my laptop, too.
                  After trying out a few different mic's...
                  07 July 2002, 09:59 Sunday
                • thadman
                  dealing with modal resonances in midrange transmission lines
                  by thadman
                  I feel modal resonances in midrange enclosures are significant enough to warrant thorough examination as to alternatives to a traditional sealed midrange, but am currently not interested in a dipole or cardiod dispersion pattern. For a traditional sealed enclosure, the largest internal dimension would...
                  05 November 2008, 19:41 Wednesday
