Difference between NHTM1 and HTM3S?
    • 1537
    Is there a difference between the Nautilus HTM1 and the HTM3S?
    Tweet, crossovers? anyone know?
    Thanks :T
    B&W
    RCD, you surprise me, thought you would know this one.
    The centres got the same treatment as the rest of the 800 range. Tweeters redesigned (similar to signatures I believe), first order crossovers, smoother more integrated sound etc.
    Other than that there may be other differences, I have not researched beyond my comment above as I am at the 804s end of the market, which the HTM3 is supposed to suit.
    • sikoniko
      • 2299
      rohelcell drivers added to the list.
        • 1537
        ops:
        Sorry..
        I asked because I was looking at a cherry HTM3S and wasnt sure if it would match my N802s as well as the HTM1.
        Well last night a cherry HTM1 popped up on Ebay, 30 mins away!! and i picked it up this morning before work!!! :B
        Im so excited. ;x(
        B&W
        • audiophied
          • 21
          Also curious about this
          I'm also in the same boat as RCD. Wondering if HTM3s would work better with N802s because of the improvements made to this model or whether I'm better off looking for an HTM-1.
          Thanks!
            • 1537
            Well, ive been jamming out for about a half hr right now and im grinnin from ear to ear!!!!
            Man, love these things!!!
            On a side note... yes I know you can see some cables... mine are backordered about another two weeks.. and my amp stands should show up this week. So yes, still progressing week to week. Just need to put in two more outlets, bury some cables and im set!
            Oh yea, acoustic treatment...
            B&W
            • alpina
              • 276
              that looks awesome christopher
              julie
              • RebelMan
                • 3139
                RCD, I really admire the progression your system and room have undergone over the last year. Keep it up, you are almost there!!! :T
